Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2009 83822 Solenoidva 00000055822
Solenoid valve
Feb. 10, 2009
Series 3824 direct acting, 2-way, 2-position or 3-way, 2-position, NC or NO solenoid valve replaces a fitting using a female inlet and male outlet port. Body is mounted into air cylinder port to control a single-acting cylinder. It is ...
Series 3824 direct acting, 2-way, 2-position or 3-way, 2-position, NC or NO solenoid valve replaces a fitting using a female inlet and male outlet port. Body is mounted into air cylinder port to control a single-acting cylinder. It is available with brass and stainless or all stainless steel pilot and nylon encapsulated coil. Basket orifice features eight sizes that can be changed to meet flow needs. It operates in pressures to 200 psi and temperatures from –10° to 50°C.
Spartan Scientific
(330) 758-8446
www.spartanscientific.com
