Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 13953products06 00000006815
Rotary selector air valves
April 13, 2006
Multi-port rotary selector valves are quiet replacements for solenoid valves. Single input can be switched between 2 to 6 output ports. They are available with detents for manual operation with a knob or without for automatic operation with a ...
Multi-port rotary selector valves are quiet replacements for solenoid valves. Single input can be switched between 2 to 6 output ports. They are available with detents for manual operation with a knob or without for automatic operation with a servo or stepper motor. Valve head has 1 in. OD and length is about 1.6 in. Non-selected ports are vented to atmosphere.
Beswick Engineering Co. Inc., (603) 433-1188, www.beswick.com
The most common valves for controlling pressure include relief, reducing, sequence, counterbalance, and unloading valves.
Oct. 13, 2021
By placing most of the valves in a fluidic system within a single manifold tucked away wherever space is available on a machine, an integrated circuit can substantially reduce...
