Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2010 86696 Levervalve 00000059298
Lever valves
Dec. 14, 2010
Manually operated three or four-way spool valves have 1/4-in. NPT ports for easy access, detented or momentary operation, and 0 to 150-psig pressure ranges, and operate at 32 to 140°F. The valves are available with either a base or panel ...
Manually operated three or four-way spool valves have 1/4-in. NPT ports for easy access, detented or momentary operation, and 0 to 150-psig pressure ranges, and operate at 32 to 140°F. The valves are available with either a base or panel mount.
Clippard Instrument Laboratory Inc.
(877) 245-6247
www.clippard.com/levervalves-m
