Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2011 87351flowcontro 00000060004
Flow control valves
May 13, 2011
Flow control valves Edited by Mary Gannon J-series combination needle and check valves regulate flow from air cylinders to control speed at which the piston strokes during extension or retraction. They allow free flow in one ...
Flow control valves
J-series combination needle and check valves regulate flow from air cylinders to control speed at which the piston strokes during extension or retraction. They allow free flow in one direction; in opposite direction, flow is metered by needle valve. JFC-4 has 1/4 in. NPT and JFC-5 has 3/8 in. NPT male threaded outlet. Features include recessed screwdriver slot or knurled knob, flow adjustment needles and female NPT or push-to-connect tubing inlets. They are rated for pressures to 150 psig and air flows of 45 (JFC-4) and 60 scfm (JFC-5) at 100 psig adjustable.
Clippard Instrument Laboratory Inc.
(877) 245-6247
www.clippard.com
