High-flow electronic valves
March 20, 2013
Clippard Minimatic Electronic valves and manifolds provide a complete system for efficient interface with electric and electronic circuits for many applications. They provide an air flow of 1.4 scfm @ 100 psig, more than twice the flow of Clippard’s trusted EC/EV/ET valve series. Optional 1.1 scfm @ 50 psig and 0.95 scfm @ 25 psig flow models are also available.
Minimatic Electronic valves and manifolds provide a complete system for efficient interface with electric and electronic circuits for many applications. Standard models provide an air flow of 1.4 scfm @ 100 psig, more than twice the flow of EC/EV/ET valve series. Optional 1.1 scfm @ 50 psig and 0.95 scfm @ 25 psig flow models are also available. Precision-built, 2-way normally-closed control valves use a unique valving principle with no sliding parts. Complete poppet travel is only 0.007 in., resulting in low power consumption and exceptionally long life.
Manifold and in-line mounting are available as well as many different electrical connection styles. Oxygen Clean and Analytical versions are also available as well as FKM, EPR and Silicone seals, and diodes.
Clippard Instrument Laboratory Inc., (513) 521-4261, www.clippard.com
