Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2010 85435 Pneumaticf 00000057822
Pneumatic fittings, valves
Feb. 10, 2010
NITRA pneumatic fittings and valves are for use with polyurethane and nylon tubing. ME and MS male straight and male elbows come in 532 and 14 in. MEL long male elbow fittings come in 532 and 14 in. with #10-32 threads. MSR ...
NITRA pneumatic fittings and valves are for use with polyurethane and nylon tubing. ME and MS male straight and male elbows come in 5/32 and 1/4 in. MEL long male elbow fittings come in 5/32 and 1/4 in. with #10-32 threads. MSR push-to-connect male straight round fittings come in ten sizes ranging from 5/32 to 1/4 in. and 4 to 6 mm. HVU three-way hand valves come in seven sizes from 1/4 to 1/2 in. and 6 to 12 mm. CVU union check valves range from 5/32 to 3/8 in. and 6 to 8 mm. Stop valves range from 5/32 to 1/2 in. and 6 to 12 mm diameters. Tubing cutter is for use with 1/8 to 1/2 in. and 4- to 12-mm flexible plastic tubing.
AutomationDirect
(800) 633-0405
www.automationdirect.com
