Proportional Flow-Control Valve
Normally closed two-way valve provides proportional flow control from direct, PFM, PNM, or PWM signal. It has 9 outlets, which can be controlled individually, in multiples of 3, or all 9. Each outlet can flow up to 180 Nl/min at 6 bar, ...
