Compact modular valves
Aug. 13, 2014
New to the NITRA line are the CMV Series of compact modular valves. Enclosed in a reinforced technopolymer protective shell that acts as a shock absorber and helps keeps dirt out, the valve’s smooth, rounded design makes it suitable for applications requiring frequent washing.
All pneumatic connections are on one side, with built-in push-to-connect fittings. The flexible system offers from one to 16 valves, with input and output terminals for tubing of different sizes. A 24-Vdc electrical signal is relayed from one valve to the next by gold-plated contacts.
The valves come in four port size combinations, and three-way/two-position, five-way/two-position and five-way/three-position configurations.
AutomationDirect, (770) 889-2858
