Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 13495 Spotlight0 00000006511
Push-to-connect fittings
Feb. 27, 2006
Newloc fittings for rigid and semirigid tubing are leak-free. Styles include Ys, 3 and 4-way connectors, Ts, reducing Ts, elbows, straight connectors, and swivels. Acetal fittings range from 1/8 to 1/2 in., and 4 to 12 mm with pressure rating ...
Newloc fittings for rigid and semirigid tubing are leak-free. Styles include Ys, 3 and 4-way connectors, Ts, reducing Ts, elbows, straight connectors, and swivels. Acetal fittings range from 1/8 to 1/2 in., and 4 to 12 mm with pressure rating of 230 psi for full vacuum. Brass fittings range from 1/8 to 1/2 in.
New Age Industries Inc., (800) 506-3924, www.newageindustries.com
How To Select Hydraulic Connectors For Leak-Free Reliability
June 14, 2016
Hydraulic oil leaks are often considered to be an inherent characteristic of hydraulic machines. While this may have been true 30 years ago, advances in sealing technology and...
