When air, vapors, or light materials must be moved easily and inexpensively, air amplifiers provide a simple solution. These devices use the
Coanda effect — the tendency of a fluid stream to be attracted to a nearby surface — to create air motion in their surroundings. Using a small amount of compressed air as their power source, air amplifiers pull in large volumes of surrounding air to produce high-volume, high-velocity outlet flows up to 25 times their consumption rate.
