Parallel and angular grippers are designed for a range of automation processes. A magnetic piston for position sensing is included on all models. Parallel grippers are available in single and double acting with seven bore sizes and two finger types, with a range of gripping force output to 144 lbf. The angular grippers are available in double and single acting with six bore sizes, and have a range of torque output to 65 lb-in.
