Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 70655 Prods0105j 00000046173
Pressure switch and transducer
Sept. 5, 2007
Series 800 switch incorporates an electronic pressure switch and pressure transducer with local indication and analog output of 4 mA or 0-10 Vdc. It provides continuous monitoring from 30-in. vacuum to 9000 psi and programs set points without ...
Series 800 switch incorporates an electronic pressure switch and pressure transducer with local indication and analog output of 4 mA or 0-10 Vdc. It provides continuous monitoring from 30-in. vacuum to 9000 psi and programs set points without pressurizing unit. Set points, contact types (PNP or NPN), and switch function (including hysteresis) easily adjust with buttons below 4-digit display. Display/programming head rotates 330° to eliminate orientation concerns during installation. Noshok Inc., (440) 243-0888, www.noshok.com
