Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 46101prods0500j 00000021297
Differential pressure gauge
March 20, 2007
Model 124 differential pressure gauge has working pressures of 10,000 psi and proof pressure of 20,000 psi. It is available with 316/316L stainlesssteel body, 316 stainless-steel springs and internal parts, as well as many elastomers. It is ...
Model 124 differential pressure gauge has working pressures of 10,000 psi and proof pressure of 20,000 psi. It is available with 316/316L stainlesssteel body, 316 stainless-steel springs and internal parts, as well as many elastomers. It is over-range protected in either direction up to 5000 psid. Available differential pressure ranges are 0 to 5 through 0 to 400 psid. Hermetically sealed, magnetically actuated reed switches are available as options that provide high and/or low alarm control.
Midwest Instrument, (586) 2546500, www.midwestinstrument.com
