Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2008 80829 Midwest121 00000053176
Differential pressure transmitter
June 10, 2008
Model 121 is a loop-powered 8-28 Vdc two-wire 4-20 mA transmitter that features a 12-in. NPT interface with an easy-to-wire industrial terminal strip and a removable cover. Accuracy is ±2% from 20% to 100% of full scale. It operates in temperatures from ...
Model 121 is a loop-powered 8-28 Vdc two-wire 4-20 mA transmitter that features a 12-in. NPT interface with an easy-to-wire industrial terminal strip and a removable cover. Accuracy is ±2% from 20% to 100% of full scale. It operates in temperatures from –20° to 150°F. It is available in aluminum or 316 stainless-steel housing with 316 stainless-steel and internal ceramic parts. Safe working pressure is 6000 psig. Units are available in pressure ranges from 0-5 to 0-110 psid.
Mid-West Instrument, (800) 648-5778, www.midwestinstrument.com
Oct. 7, 2021
