Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 11 01 2007 76367positionse 00000048968
Position sensors
Nov. 21, 2007
Series 9G linear magnetic position sensors work with extruded pneumatic aluminum cylinders that have 6.2 x 4.4 mm rectangular T-slot groove in the body. They are available in reed NPN or PNP electronic versions and operate to 30 G in the ...
Series 9G linear magnetic position sensors work with extruded pneumatic aluminum cylinders that have 6.2 x 4.4 mm rectangular T-slot groove in the body. They are available in reed NPN or PNP electronic versions and operate to 30 G in the reed version and 50 G in the electronic version. They meet NEMA 6 standards and are water and dust tight to IP-67 specifications. Electrical connection is made by either flying lead or 8 mm quick connect versions.
Canfield Connector, (330) 758- 8299, www.canfieldconnector.com
