Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2008 78422lineartran 00000051061
Linear Transducers
Feb. 15, 2008
LA linear transducers have a small footprint so pin-to-pin dimensions of existing cylinders do not need to change. A microprocessor controls and receives signals to PCB surface-mounted Hall Effect chips. The PCB is inserted into a ...
LA linear transducers have a small footprint so pin-to-pin dimensions of existing cylinders do not need to change. A microprocessor controls and receives signals to PCB surface-mounted Hall Effect chips. The PCB is inserted into a stainless-steel or aluminum housing and a magnet causes a voltage drop. The microprocessor understands the Hall Effect chip’s position and correlates voltage drop to a proportional voltage, current, PWM, or CANBUS outputs.
Rota Engineering,
(972) 359-1041,
www.rota-eng.com
