Position sensor incorporates an integral clamp that fixes directly to NFPA tie rod cylinders. It uses the latest magneto resistive technology and is available in either reed switch, solid-state NPN/PNP configurations, with LEDs standard. It comes with ...
Position sensor incorporates an integral clamp that fixes directly to NFPA tie rod cylinders. It uses the latest magneto resistive technology and is available in either reed switch, solid-state NPN/PNP configurations, with LEDs standard. It comes with either 3M flying lead or M8 quick disconnect. It offers 30 and 50 G shock ratings and 9 G vibration ratings. It has a switching rating of 10 W maximum and is rated to IP67.
