BMF 273 sensor is designed for use with C-slot-equipped pneumatic cylinders. It indicates piston stroke end position, is just 25.7 mm long, and fits completely within a standard C-slot. It is secured by a nonstripping screw, while the cable ...
BMF 273 sensor is designed for use with C-slot-equipped pneumatic cylinders. It indicates piston stroke end position, is just 25.7 mm long, and fits completely within a standard C-slot. It is secured by a nonstripping screw, while the cable is equipped to be secured within the C-slot by a mini pop-in fastener. Accurate, low hysteresis sensor replaces Reed and Hall-Effect switches, comes with an LED indicator, and uses magnetoresistive technology.
