Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2008 80321differenti 00000052763
Differential Pressure Transmitter
May 14, 2008
Model 220 pressure transmitter provides a simple, loop-powered 828 Vdc, two wire 4-20 mA transmitter option using a CSA-, UL-, and ATEXrated sensor and explosion-proof housing. Wiring access is through a 12-in. NPT port. Accuracy is ±2% ...
Model 220 pressure transmitter provides a simple, loop-powered 828 Vdc, two wire 4-20 mA transmitter option using a CSA-, UL-, and ATEXrated sensor and explosion-proof housing. Wiring access is through a 12-in. NPT port. Accuracy is ±2% from 20% to 100% of full scale. Indicator accuracy is ±2% and is independent of transmitter. Its working pressure is 4000 psig. Differential ranges are available from 0-5 to 0-100 psid.
Mid-West Instrument, (800) 648-5778, midwestinstrument.com
