Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 70112 Prods0204j 00000045810
Differential pressure sensors
Aug. 10, 2007
Model DP86 wet-wet differential pressure sensors reduce measurement error in fluid flow, for low pressure gas. They are double-sided, stainless steel, isolated, piezoresistive silicon pressure sensors that are designed for O-ring mounting. Seven ...
Model DP86 wet-wet differential pressure sensors reduce measurement error in fluid flow, for low pressure gas. They are double-sided, stainless steel, isolated, piezoresistive silicon pressure sensors that are designed for O-ring mounting. Seven differential pressure ranges are available, ranging from 0 to 500 psi.
Measurement Specialties Inc., (510) 498-1570, www.meas-spec.com
