Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2010 85445 Differenti 00000057833
Differential pressure switches
Feb. 10, 2010
Edited By Mary C. Gannon Posed piston-type differential pressure switch is essentially two static O-ring type pressure sensors connected at opposite ends of a common piston shaft. Weathertight or explosion proof models are available. Features ...
Posed piston-type differential pressure switch is essentially two static O-ring type pressure sensors connected at opposite ends of a common piston shaft. Weathertight or explosion proof models are available. Features include a wide variety of wetted parts, rugged construction, high-cycle rate tolerance, long life, narrow dead band, high overrange and proof pressures, self-locking adjustment, and a pressure range of 0.5 to 1000 psid.
SOR Inc.
(800) 676-6794
www.sorinc.com
