PCFP25 magnetostrictive linear position sensors feature thin, industrial-grade housing that is 0.32 in. high and 1.10 in. wide. It is maintenance-free and is designed for tight locations or for areas with limited access. It offers analog ...
PCFP25 magnetostrictive linear position sensors feature thin, industrial-grade housing that is 0.32 in. high and 1.10 in. wide. It is maintenance-free and is designed for tight locations or for areas with limited access. It offers analog outputs of 0-10 Vdc and 4-20 mA. CAN-Bus versions are also available. Series is available with a measurement range to 18 ft and achieves an IP64 enclosure protection rating.
