Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 46112prods0200j 00000021307
Tilt safety switch
March 20, 2007
Dual-axis tilt safety switch replaceselectromechanical-type level sensors by combining dual-axis True Tiltsensor technology with embedded micro-controller containing signalconditioning circuitry for accurate, repeatable, and safe tilt outputs. Features ...
Dual-axis tilt safety switch replaceselectromechanical-type level sensors by combining dual-axis True Tiltsensor technology with embedded micro-controller containing signalconditioning circuitry for accurate, repeatable, and safe tilt outputs. Features include fast installation with infrared light source programming, factory programmed trip points, damping and delays, OEM reprogramming of trip point angles, auto zero to eliminate mechanical zeroing, and hermetic sealing from dirt and moisture.
The Fredericks Co., (215) 947-2500, www.frederickscom.com
How To Select Hydraulic Connectors For Leak-Free Reliability
June 14, 2016
Hydraulic oil leaks are often considered to be an inherent characteristic of hydraulic machines. While this may have been true 30 years ago, advances in sealing technology and...
