Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2007 73323transducer 00000047568
Pressure transducers, transmitters
Oct. 18, 2007
Series 1500 transducers and transmitters provide pressure monitoring in hazardous environments. All-welded stainless steel construction eliminates mechanical fasteners, washers, O-rings, and fluid fills, to increase reliability and long-term ...
Series 1500 transducers and transmitters provide pressure monitoring in hazardous environments. All-welded stainless steel construction eliminates mechanical fasteners, washers, O-rings, and fluid fills, to increase reliability and long-term repeatability. Full-scale ranges are available, from full vacuum to 6000 psi, with accuracies of 0.5%, 0.25%, and 0.1%. Units are supplied with 0-5 Vdc; 0-10 Vdc; or loop-powered 4-20 mA output signals, with choice of pressure port and electrical connectors.
PCB Piezotronics Inc., (888) 684-0011, www.pcb.com
Circle 161
