Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2009 83823 Proximitys 00000055829
Proximity sensors
Feb. 10, 2009
Series 7000 proximity sensors detect piston position on 2- to 8-in. bore tie rod cylinders. Selfadjusting clamp grips standard NFPA and custom cylinders. Range of custom circuits includes 1- or 4-A reed switches; NO, NC, or SPDT switch ...
Series 7000 proximity sensors detect piston position on 2- to 8-in. bore tie rod cylinders. Selfadjusting clamp grips standard NFPA and custom cylinders. Range of custom circuits includes 1- or 4-A reed switches; NO, NC, or SPDT switch types; reed or electronic sensing elements; and 120 Vac Hall sensor. They allow for use of one switch for a majority of voltages and cylinder sizes, are compatible with intrinsically safe barriers, and operate in a temperatures from –20° to 80°C.
Canfield Connector
(330) 758-8299
www.canfieldconnector.com
Seals for Hydraulic Cylinders
Dec. 19, 2019
Pressure has been mounting to design and produce cylinders that offer superior sealing performance for enhanced reliability. This article provides an overview of hydraulic cylinders...
A Checklist for Matching Pneumatic Cylinders to Load Requirements
June 8, 2023
Several calculations can be used to appropriately size pneumatic cylinders for a given application.
