Control module
July 11, 2006
CL-202 CanLink control is a solid-state microprocessorbased module that provides multiple inputs in one location. It incorporates 16 low current switch-to-battery type inputs and four switch-to-ground harness codes for additional inputs. It ...
CL-202 CanLink control is a solid-state microprocessorbased module that provides multiple inputs in one location. It incorporates 16 low current switch-to-battery type inputs and four switch-to-ground harness codes for additional inputs. It features an operating range of 8 to 32 Vdc and temperature range of -40° to 85° C. Input configurations for frequency and resistive dependent sensor inputs are available.
HED Inc., (262) 673-9450, www.hedonline.com
Oct. 7, 2021
