Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2009 85075 Highpressu 00000057431
High-pressure sensor
Dec. 10, 2009
Edited By Mary C. Gannon Dual-channel pressure sensor measures pressures to 4000 psia for hydraulic systems in aircraft. Media isolated, oil-filled, piezo-resistive sensing technology allows it to operate in harsh, flight critical ...
Dual-channel pressure sensor measures pressures to 4000 psia for hydraulic systems in aircraft. Media isolated, oil-filled, piezo-resistive sensing technology allows it to operate in harsh, flight critical environments with a typical MTBF of 300,000 hr at nominal operating temperatures. Burst pressure is nearly 2X the URL, and the operating temperature is -67º to 257ºF. It operates on supply of 5 to 15 Vdc, and provides a non-amplified 0-100 mV output at 10 Vdc excitation. Accuracy is ±1% of full scale output over an operating temperature range of 0 to 200ºF.
Kavlico - Aerospace, (805) 523-2000, www.kavlico.com
