Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 02 Omega Dpgm409
Metric pressure gauges
Feb. 14, 2012
DPGM409 pressure gauges are available for gauge, sealed gauge, absolute, compound gauge, vacuum, and barometric pressure ranges from 25 mbar to 245 bar.
DPGM409 pressure gauges are available for gauge, sealed gauge, absolute, compound gauge, vacuum, and barometric pressure ranges from 25 mbar to 245 bar. Core is a micromachined silicon sensor with 0.08% accuracy. User selectable a
nalog output of either 0 to 5 Vdc, 0 to 10 Vdc or 4 to 20 mA is standard; a built-in wireless transmitter is also available. Electronics are enclosed in stainless steel, ABS housing that is washdown rated. Display has large 25.4 mm (1 in.) digits plus a 0 to 100% bar graph.
Omega Engineering Inc., (203) 359-1660, www.omega.com
