Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 03 A Series Pres Ss 06 A
Miniature pressure switches
March 6, 2012
A-Series pressure switches are designed for tough OEM and industrial applications. Available with explosion-proof and watertight enclosures, they feature a refined piston actuator that can be ranged up to 2000 psi while enduring a working pressure of 5000 psi.
A-Series pressure switches are designed for tough OEM and industrial applications. Available with explosion-proof and watertight enclosures, they feature a refined piston actuator that can be ranged up to 2000 psi while enduring a working pressure of 5000 psi. Small dimensions, a choice of connections and a field adjustable set point make them easy to configure and install in nearly any alarm, shutdown or control application.
Ashcroft Inc., (800) 328-8258, www.ashcroft.com
