Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 09 Jr Merritt Ns2 Kb
AC and DC joysticks
Sept. 11, 2012
NS2/NSB2-KB series of compact joystick controllers are intended for use in mills, process lines, foundries, mining shovels, etc. under continuous duty cycles. Small footprint and mounting hole pattern allows for direct replacement of master switches. Their cast construction is sealed to IP65.
NS2/NSB2-KB series of compact joystick controllers are intended for use in mills, process lines, foundries, mining shovels, etc. under continuous duty cycles. Small footprint and mounting hole pattern allows for direct replacement of master switches. Their cast construction is sealed to IP65. Step or stepless AC and DC controls can accommodate specific control requirements with a variety of standard and custom-engineered configurations. Contact drive can be rotated for panel layout versatility. Optional handle configurations include pushbutton, mechanical interlock, and rocker switch handles. Proportional and discrete outputs include (but not limited to) potentiometer, 4-20 mA, 10 V amplifier, CANbus.
J.R. Merritt Controls Inc., (203) 381-0100, www.jrmerritt.com
