Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2011 86958 Pressuresw 00000059607
Pressure switches
Feb. 16, 2011
By Mary C. Gannon, Senior Associate Editor Weatherproof pressure switches with standard wetted parts are suitable for air, oil, water, and non-corrosive fluids. They are rated for pressures from 30-in. Hg vacuum to 7000 psi. Pressure sensing element ...
By Mary C. Gannon,
Weatherproof pressure switches with standard wetted parts are suitable for air, oil, water, and non-corrosive fluids. They are rated for pressures from 30-in. Hg vacuum to 7000 psi. Pressure sensing element is a force-balanced piston-actuated assembly and sealed by a flexible diaphragm and static O-ring. Features include high-cycle rate tolerance, self-locking adjustment, high over-range and proof pressures, narrow deadband and high resistance to corrosive and hostile environments.
SOR Inc., (913) 888-2630, www.sorinc.com
