Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2011 86963 Halleffect 00000059612
Hall-effect joystick
Feb. 16, 2011
By Mary C. Gannon, Senior Associate Editor XL-VNSO Hall-effect joystick controller is available as 1-, 2- and 3-axis design and provides precise proportional control of electrohydraulic proportional valves and will also accommodate applications that ...
By Mary C. Gannon,
XL-VNSO Hall-effect joystick controller is available as 1-, 2- and 3-axis design and provides precise proportional control of electrohydraulic proportional valves and will also accommodate applications that require digital or analog command signals to control variable-speed drives, PLCs, and microprocessors, including CAN bus. It is made with NiCr gimbal yokes, hardened steel bearings, polished steel shaft guides, bronze gate handle stops and dual compression return springs in each axis.
J.R. Merritt Controls Inc., (203) 381-0100, www.jrmerritt.com
