Pressure gauge has front flange for panel mounting
Sept. 10, 2013
All-welded front-flanged 2008S panel builder’s pressure gauge combines stainless-steel wetted parts and case with company's PowerFlex spring-suspended movement.
All-welded front-flanged 2008S panel builder’s pressure gauge combines stainless-steel wetted parts and case with company's PowerFlex spring-suspended movement for reliability and longevity. The gauge’s dial is 63 mm in diameter. Also available are liquid filled and Plus! performance to dampen potential pointer bounce caused by vibration and pulsation.Ashcroft Inc., 800.328.8258, www.ashcroft.com
