Oil Conditioner and Stop Leak
Feb. 17, 2015
Oil Booster & Stop Leak is an additive for hydraulic systems that is said to reduce seal leaks and can be used in new equipment to stop initial wear and increase fluid life. The additive
Oil Booster & Stop Leak is an additive for hydraulic systems that is said to reduce seal leaks and can be used in new equipment to stop initial wear and increase fluid life. The additive is formulated to reduce operating temperature and increase the life of hoses, rams, and cylinders and serve as an inexpensive preventive maintenance product. It comes in 12-qt or 4-gal cartons, 5-pail, 16-gal keg, or 55 –gal drum.
LUCAS OIL CO., (800) 342-2512
