61298443 © Boggy | Dreamstime.com
Improving quality control can strengthen manufacturing outcomes for fluid power and electromechanical components
Understanding and Improving Quality Control to Optimize System Performance
April 28, 2025
Embedding quality into the manufacturing process can prevent defects and enhance product longevity for fluid power and electromechanical motion control devices.
Precision is the foundation of modern manufacturing, especially in industries built around fluid power and electromechanical motion control systems. When quality control falters, system efficiency drops, performance degrades and costly failures follow.
For engineers, designers and technicians specifying critical components, understanding quality control is not just important — it’s essential to achieving lasting reliability. Effective quality control goes beyond inspecting finished parts. It requires embedding precision into every phase of production, from initial material selection to final system integration.
Whether you’re sourcing components for a high-pressure hydraulic system or designing larger motion control assemblies, mastering quality control practices can strengthen your manufacturing outcomes and enhance every system you help build.
Optimizing System Performance Through Quality Control
In fluid power and electromechanical systems, the relationship between component quality and system performance is direct and unforgiving. Valves, actuators, pumps and controllers must operate reliably under varying pressures, temperatures and mechanical loads. Even slight deviations from specifications — i.e. dimensions, material properties and assembly methods — can cascade into significant operational failures.
Manufacturers must approach quality control as a continuous, strategic process. It begins with defining precise specifications that eliminate ambiguity. Every material grade, surface finish, dimensional tolerance and performance requirement must be clearly articulated to suppliers and internal teams. Ambiguity at the design stage opens the door for variability later — and when components must seal, regulate and transmit force precisely — variability is often synonymous with system failure.
Specifying high-integrity components such as chilled water valves requires a detailed understanding of operating conditions. Poor material selection or dimensional drift during production can compromise thermal management in critical cooling systems, leading to efficiency losses or complete shutdowns.
Best Practices for Strengthening Quality Control
Effective quality control is built on several core principles, all of which must work together to drive consistent outcomes. It begins with rigorous material verification. Raw materials form the backbone of manufactured products, and their quality dictates the starting point of every component’s integrity. Materials must be tested for composition, mechanical properties and compliance with industry standards before they enter the production floor.
In-process quality checks are equally vital. Monitoring key dimensions, surface conditions and assembly parameters during production helps catch deviations early, preventing the escalation of minor defects into systemic failures. For components used in hydraulic circuits or precision motion systems, tolerances often sit within microns. Measuring tools such as coordinate measuring machines (CMMs) and laser profilometers provide the accuracy required to verify that parts meet stringent requirements.
Final product testing closes the loop by validating that components function under conditions that simulate real-world applications. For motion control assemblies, there are pressure tests, thermal cycling and functional simulations which can confirm that every unit can withstand its expected operational demands.
Importantly, quality control does not end when a part passes final inspection. Ongoing monitoring of field performance feeds valuable information back into design and manufacturing processes, supporting continuous improvement.
Read "Subjective Quality Testing is Becoming a Thing of the Past" to learn about how product testing is evolving.
Embedding Precision in the Manufacturing Process Ensures Product Longevity
True quality control is not reactive; it is preventive. Embedding quality into the process itself eliminates many defects before they occur. This begins with well-documented work instructions that guide operators through each production step with clarity and precision. Clear documentation standardizes practices, reduces variability and enhances repeatability, particularly in assembly operations involving seals, fittings and high-pressure connections.
Training plays a pivotal role in this effort. Operators, inspectors and engineers must understand not just what to do, but why precision matters. When a technician installing a hydraulic actuator recognizes the impact of torque values on seal integrity, quality becomes personal and meaningful rather than procedural.
Preventive maintenance of production equipment further supports embedded quality. Machines that drift out of calibration introduce errors even if operators follow correct procedures. Regular calibration schedules, condition monitoring and predictive maintenance techniques maintain machine performance and protect part integrity.
The Importance of Employing Root Cause Analysis
When quality deviations do occur, root cause analysis (RCA) is the tool that transforms mistakes into learning opportunities. Rather than simply correcting defective products, RCA seeks to identify the underlying factors that allowed the defect to occur. This structured approach drives systemic improvements rather than superficial fixes.
For example, if a pneumatic actuator consistently fails leak tests, RCA may reveal contamination introduced during assembly or tool wear that affects dimensional accuracy. Corrective actions then address the true source of the problem, preventing recurrence and protecting downstream systems from failure.
Failure Mode and Effects Analysis (FMEA) complements RCA by proactively identifying and mitigating potential failure points during the design and process planning stages. In industries where motion control reliability underpins critical operations, proactive risk reduction is an indispensable part of quality control.
Digital Technologies are Helping Improve Quality Control
As manufacturing embraces digital transformation, quality control is evolving. Digital inspection technologies — such as 3D scanning and automated optical inspection — allow faster, more comprehensive evaluations of complex parts. Internet of Things (IoT) sensors embedded in production equipment can provide real-time data on process variables like pressure, vibration and temperature, alerting operators to deviations before they result in defects.
Machine learning algorithms can also analyze quality data to predict trends and identify areas for process optimization. In fluid power applications, predictive analytics may forecast seal wear based on historical performance data, supporting preventive maintenance schedules that protect system uptime.
Digital tools can enhance traceability as well. Detailed digital records of material batches, production parameters and inspection results create a transparent chain of custody that supports both internal quality initiatives and external audits.
Continuous Improvement Leads to Elevated Quality and Competitive Advantages
Quality in manufacturing is not just a requirement; it is a competitive differentiator. Companies that invest in robust quality control programs position themselves to deliver components and systems that outperform competitors in reliability, longevity and customer satisfaction.
Continuous improvement frameworks, such as Plan-Do-Check-Act (PDCA) cycles and Lean Six Sigma methodologies, provide structured pathways to elevate quality over time. In fluid power and other motion control industries where system reliability often defines customer value even small quality gains translate into substantial competitive advantages.
Manufacturers that embed quality thinking into their organizational culture going forward have the power to build resilience, agility and trust with their customers.
Understanding and improving quality control practices — from precise component specification to advanced digital inspection — empowers engineers, designers and technicians to build systems that deliver consistent, high-level performance. By prioritizing precision, proactive prevention and continuous learning, manufacturing teams can strengthen outcomes across design, production and field deployment.
This article was written and contributed by Larry Rayhon, Senior Director of Product Engineering at Marotta Controls.
Larry Rayhon | Senior Director of Product Engineering, Marotta Controls
Larry Rayhon is Senior Director of Product Engineering at Marotta Controls. For nearly 30 years, Rayhon has contributed to the success of key programs for customers and has recently taken the roll in leading all operations for Marotta’s power and actuation business unit. Joining Marotta in 1988, he spent 10 years leading the development group and transitioning many key programs from development to production.
Nov. 21, 2022
Use of hydraulics is best determined by considering the requirements of an application as well as several other factors.
