Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 04 01 2010 85668 Cylinderho 00000058203
Cylinder hones
April 14, 2010
HTD tube hone features stroke to 16 m (52 ft), bores to 1000 mm (39 in) diameter. Electronically-controlled spindle motor powers stock removal to 2500 cm3/hr (150 in.3/hr) for fast, accurate honing of hydraulic cylinders, other components. The machine ...
HTD tube hone features stroke to 16 m (52 ft), bores to 1000 mm (39 in) diameter. Electronically-controlled spindle motor powers stock removal to 2500 cm3/hr (150 in.3/hr) for fast, accurate honing of hydraulic cylinders, other components. The machine corrects bore geometry and size errors and produces specific surface finishes and crosshatch angles to ensure correct sliding sealing surfaces between mating parts. Machine has Windows-based controller to ensure optimum control of bore geometry and is well suited for controlling taper variation and drift in long bores.
Sunnen Products Co.,
(314) 781-2100, www.sunnen.com
