Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2008 80821 Dadco H Pser 00000053168
Air cylinders
June 10, 2008
HP.N non-rotating metric air cylinders feature adjustable cushion control, aluminum piston, built-in lubrication system, and position sensing capability, along with a stainless-steel square rod that prevents rotation. They are available in multiple bore ...
HP.N non-rotating metric air cylinders feature adjustable cushion control, aluminum piston, built-in lubrication system, and position sensing capability, along with a stainless-steel square rod that prevents rotation. They are available in multiple bore sizes from 32 to 100 mm and in strokes from 25 to 500 mm. A variety of mounting options and accessories are available.
DADCO Inc., (800) 323-2687, www.dadco.net
