AMLOK hydraulic RCH rod clamps provide power-off clamping of rods and shafts. They are actuated by a spring/collet mechanism and unclamped by hydraulic pressure. Clamping is done after motion has stopped. Mountings apply to standard heavy duty ...
AMLOK hydraulic RCH rod clamps provide power-off clamping of rods and shafts. They are actuated by a spring/collet mechanism and unclamped by hydraulic pressure. Clamping is done after motion has stopped. Mountings apply to standard heavy duty NFPA-style MF1 cylinders. They are designed for locking reciprocating motions only. Units are available for both rotating and reciprocating motions.
Advanced Machine & Engineering (815) 962-6076
www.ame.com
