Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2009 84862 Pneumaticc 00000057201
Pneumatic cylinders
Oct. 7, 2009
Edited by Mary C. Gannon Self-adjusting cushioning DSNU-PPS cylinders require no manual intervention to adjust end-position cushioning, even with friction and pressure changes. Combination of three different bearing caps and four end caps gives them ...
Self-adjusting cushioning DSNU-PPS cylinders require no manual intervention to adjust end-position cushioning, even with friction and pressure changes. Combination of three different bearing caps and four end caps gives them four mounting options, including block-design end caps for direct mounting or with flange threads; end caps with threaded lugs and swivel bearings, with air supply connections that are lateral; or in-line with the cylinder axis.
Festo Corp.
(800) 993-3786
www.festo.com
