CST series pneumatic stopper cylinder is designed for light and medium duty applications. It can be used in work holding fixture and conveyor system applications and is available in 32-mm bore size with a 20-mm stroke; and 40 and 50 mm bore ...
CST series pneumatic stopper cylinder is designed for light and medium duty applications. It can be used in work holding fixture and conveyor system applications and is available in 32-mm bore size with a 20-mm stroke; and 40 and 50 mm bore sizeswith a 30 mm stroke. Oversized piston rod diameter maximizes effective bearing area for impact resistance. Basic stopper cylinder types include shaft, roller, and toggle-lever versions.
