Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2010 85880 Positioncy 00000058530
Position cylinder
June 11, 2010
Edited By Mary C. Gannon PDH position cylinder is available in 2.5 to 5 in. bores and rated to 3000 psi. All sensor components (except electrical connector) are imbedded internally within the cylinder for durability and long field life. Internal ...
PDH position cylinder is available in 2.5 to 5 in. bores and rated to 3000 psi. All sensor components (except electrical connector) are imbedded internally within the cylinder for durability and long field life. Internal electronic feedback senses cylinder rod position and provides output (analog or digital) to allow constant monitoring of the cylinder rod position. Sensor voltage supply is 12 or 24 Vdc.
Cross Mfg., (620) 324-5525, www.crossmfg.com
