Non-rotating, high-powered thruster achieves strokes to 20 in. One-piece end caps house twin 2 1/2 in. bore cylinders for power to eliminate deflection or drift within cylinder bodies. Locking mechanism keeps cylinder in extended position in case ...
Non-rotating, high-powered thruster achieves strokes to 20 in. One-piece end caps house twin 2 1/2 in. bore cylinders for power to eliminate deflection or drift within cylinder bodies. Locking mechanism keeps cylinder in extended position in case of air loss. Numatics, (615) 771-1200, www.numatics.com
