Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2007 73313airpng 00000047557
Air cylinder
Oct. 18, 2007
P1M swing clamp cylinder’s stressproof steel bearing tolerates high torques. It is available in 32-, 40-, and 50-mm bore sizes in single-rod configurations with set stroke lengths of 10, 20, and 50 mm depending on bore size. Clamping ...
P1M swing clamp cylinder’s stressproof steel bearing tolerates high torques. It is available in 32-, 40-, and 50-mm bore sizes in single-rod configurations with set stroke lengths of 10, 20, and 50 mm depending on bore size. Clamping direction can be right-hand clockwise or left-hand counterclockwise rotation. Clamp forces depend on operating air pressure from 27 lb for 32-mm bore at 29 psi to 371 lb for 50-mm bore at 145 psi. Maximum operating pressure is 10 bar.
Parker Hannifin Corp., Actuator Div., (866) 727-5228, www.parker.com/actuator
Circle 152
