Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 07 01 2008 81344aircylinde 00000053545
Air cylinders
July 16, 2008
KG series air cylinders/valve actuators come with aluminum tubes standard on 112- to 8-in. bore cylinders (with the exception of 7-in. bore). Aluminum tube is hard coat anodized with an electrochemical process that produces a ...
KG series air cylinders/valve actuators come with aluminum tubes standard on 112- to 8-in. bore cylinders (with the exception of 7-in. bore). Aluminum tube is hard coat anodized with an electrochemical process that produces a very dense surface of aluminum oxide to offer extreme hardness (60 RC.), high wear and corrosion resistance, and low coefficient of friction. They are available in 17 bores sizes ranging from 112 to 24 in. and piston rod diameters range from 58 to 312 in.
Numatics, (615) 771-1200, www.numatics.com
