Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 13923use Prods01 00000006787
Hydraulic cylinders
April 13, 2006
Short-stroke, lug-mounted hydraulic linear actuators have a short coupling between rod guides and piston heads for reaction to side loads and moments. They are available in bores of 0.75 to 1.563 in. and are rated for 1500 psi with strokes to 2 ...
Short-stroke, lug-mounted hydraulic linear actuators have a short coupling between rod guides and piston heads for reaction to side loads and moments. They are available in bores of 0.75 to 1.563 in. and are rated for 1500 psi with strokes to 2 in.
Mack Corp., (928) 526-1120, www.mackcorp.com
