Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2010 86400 Pneumaticm 00000059065
Pneumatic mini slide
Oct. 13, 2010
Edited By Mary C. Gannon DGSL ultraprecise slide is used for positioning or as a pick-and-place system. It features an integrated bearing system with 0.01-mm accuracy, linearity, and parallelism. Eight sizes are offered from 4 to 20-mm diameter, ...
DGSL ultraprecise slide is used for positioning or as a pick-and-place system. It features an integrated bearing system with 0.01-mm accuracy, linearity, and parallelism. Eight sizes are offered from 4 to 20-mm diameter, with strokes to 200 mm. Optional clamping unit and end-position interlock prevents lowering of loads onto workpiece carriers in case of compressed-air-supply failure and provides protection in emergency-stop situations. Three different end-stop systems — shock-absorber, cushioned metal stops, polymer stops — are available.
Festo Corp., (631) 435-0800, www.festo.com/usa
