Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2007 7724852airpng 00000049572
Air cylinders
Dec. 19, 2007
Air cylinders MQ cylinder assemblies minimize sliding friction for breakaway pressure down to 0.001 MPa. MQQ comes in 10-, 16-, 20-, 25-, 30-, and 40-mm bores for pressures from 0.005 to 0.5 MPa and speeds from 0.3 to 500 mm/ sec. ...
Air cylinders
MQ cylinder assemblies minimize sliding friction for breakaway pressure down to 0.001 MPa. MQQ comes in 10-, 16-, 20-, 25-, 30-, and 40-mm bores for pressures from 0.005 to 0.5 MPa and speeds from 0.3 to 500 mm/ sec. Strokes range from 10 to 100 mm. MQM offers speeds to 3 m/sec and comes in 10-, 16-, 20-, and 25-mm bores for pressures from 0.005 to 0.7 MPa. Strokes range from 15 to 100 mm. Miniature MQP offers pressures down to 0.001 MPa and comes in 4-, 6-, 10-, 16-, and 20-mm bore sizes. Stroke is 10 mm.
SMC Corp. of America, (714)-669-0941, www.smcusa.com
