Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 18225nonrotatin 00000010279
Non-rotating cylinders
June 5, 2006
HP.N non-rotating metric air cylinders feature adjustable cushion control, aluminum piston, built-in lubrication, and position-sensing. They are available in bore sizes from 32 to 100 mm for strokes from 25 to 500 mm. Stainless-steel square rod ...
HP.N non-rotating metric air cylinders feature adjustable cushion control, aluminum piston, built-in lubrication, and position-sensing. They are available in bore sizes from 32 to 100 mm for strokes from 25 to 500 mm. Stainless-steel square rod prevents rotation. Dadco, (800) 323-2684, www.dadco.net
