JSC3 Series double-acting cylinders are spring applied/ released static and dynamic mounted at the rod end. The has a stopping accuracy of at 300 mm/sec piston (with no load). An internal brake-release valve matched to the application simpli
JSC3 Series double-acting cylinders are spring applied/ released static and dynamic mounted at the rod end. The has a stopping accuracy of at 300 mm/sec piston (with no load). An internal brake-release valve — matched to the application — simplifies piping and saves space. The brake can be actuated by signals from a series of tierodmounted, external reed or proximity switches intermediate stop
housing protects the JIS selected for endurance and brake status indicator is pneumatic or electric power is automatically applied the brake, provision is into a threaded hole and prelubricated tubes are and tie rods are steel; the magnet — is die-cast mounting styles are available, are optional.
Make contact: CKD Corp., Rolling Meadows, Ill. (847) 437-9727, www.ckdusa.com
Pressure has been mounting to design and produce cylinders that offer superior sealing performance for enhanced reliability. This article provides an overview of hydraulic cylinders...
Rodless cylinders are used primarily for their compact design—they provide the same stroke of conventional cylinders, but in roughly half the space. But they hold other advantages...
