Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 13922use Prods01 00000006786
Air cylinders
April 13, 2006
NFPA interchangeable air cylinders have oversized nonmetallic, composite rod bearings for maximum load support, wear resistance, and long cycle life. They are offered in bores from 11/2 to 6 in. and strokes to 48 in. Cylinder heads and caps are ...
NFPA interchangeable air cylinders have oversized nonmetallic, composite rod bearings for maximum load support, wear resistance, and long cycle life. They are offered in bores from 11/2 to 6 in. and strokes to 48 in. Cylinder heads and caps are machined from solid aluminum bar stock and black anodized for corrosion resistance. Cylinder barrels are hardcoated aluminum alloy tube.
Fabco-Air Inc., (352) 373-3578, www.fabco-air.com
